Home » Audio » Thermionic Emissions » SET Kits
SET Kits [message #10672] Tue, 17 August 2004 17:54 Go to next message
WhyAskWhy is currently offline  WhyAskWhy
I hear good things and would like to build a single triode amp. What kits are available?
Re: SET Kits [message #10675 is a reply to message #10672] Wed, 18 August 2004 15:06 Go to previous messageGo to next message
WAW,
Just search for "kits" here and you'll find a bunch of posts. Bottlehead, Welborne Labs and Audio Note immediately come to mind. I have used a pair of Welborne Laurels -- now discontinued in favor of their DRD amps -- for years and love them.
What kind of speakers do you have; how large is your listening area; and what sorts of music do you like, and at what volumes? The answers to those questions may influence what you get. Others may disagree, but even with sensitive speakers, 2A3 amps, which put out c. 3 to 3.5W, have never had enough oomph for me, so unless you report that you have very sensitive speakers and listen exclusively to solo or small acoustic ensembles at low levels in a small space, I'd suggest a 300B amp (c. 8W). But even then, we've got to make sure your speakers are SET-friendly.
Re: SET Kits [message #10676 is a reply to message #10672] Thu, 19 August 2004 08:30 Go to previous messageGo to next message
Check out bottlehead.com. Doc just came out with a new SET kit for around $350. I ordered one earlier in the week.....Colin
Re: SET Kits [message #10677 is a reply to message #10672] Thu, 19 August 2004 14:57 Go to previous messageGo to next message
davecpl is currently offline  davecpl
Be sure to look at
S.E.X.! [message #10678 is a reply to message #10676] Thu, 19 August 2004 15:16 Go to previous messageGo to next message
Colin,
Having built two Foreplays -- one from a kit, the other a clone -- I'm a fan of Doc B. However, his new SEX amp outputs about 2W, so you've got to be real careful about what speakers you mate it with. Doc's suggestion to use it to drive a pair of computer speakers (i.e., very, very nearfield listening) looks intriguing.
What speakers are you going to be mating your SEX with (if you don't mind me getting personal)?
Re: S.E.X.! [message #10679 is a reply to message #10678] Thu, 19 August 2004 15:50 Go to previous messageGo to next message
Will be ordering a pair of Pi's in the near future!!!!!!!
Re: S.E.X.! [message #10680 is a reply to message #10679] Fri, 20 August 2004 05:01 Go to previous messageGo to next message
Great speakers! As the owner of Studio 2s and Theater 4s, I'll be interested to hear about SEX with Pi (wasn't that a movie?).
Nice Pix [message #10681 is a reply to message #10680] Fri, 20 August 2004 07:17 Go to previous messageGo to next message
Nice shots.
I'm going to go with either the 1 or 2 Pi bass reflex. The towers would be nice, but I just don't have the skill (or tools) to do them justice. I'm going to have a local cabinet shop cut the wood for me, and if the price is right have them do the assembly.
I'm really interested in building the Pi speakers, so I can see how my Cayin TA-30 sounds in SE mode. Since I've had the Cayin, I have only run it in PP (35W) with my Maggies......Colin
Re: S.E.X.! [message #10682 is a reply to message #10678] Fri, 20 August 2004 16:22 Go to previous messageGo to next message
Kevin T is currently offline  Kevin T
Looks like a re-release of the kit from way back when.
Audio Electronic AE-25 [message #10683 is a reply to message #10672] Sun, 22 August 2004 18:32 Go to previous messageGo to previous message
Ranier is currently offline  Ranier
Sorry for the cross posting but in case you haven't seen...
Previous Topic: OTL amps
Next Topic: 11BM8 tube amp kits
Current Time: Sun Nov 29 18:09:12 CST 2026
