| flanking subs with small mains [message #75604] |
Fri, 22 February 2013 13:37  |
dheflin44
Messages: 47 Registered: November 2012 Location: Carrollton, TX
Baron |
Hi Wayne,
My current mains are fairly small (usable output only down to 60 Hz), so I've been searching for a way to blend in flanking subs while using my AVR's bass management to limit the main's extension below 80Hz. Please let me know if you think the general idea below is worth pursuing.
Since the AVR can't output overlapping sub and main outputs when bass management is used, I'd like to generate the overlap by using the line-level inputs on the flanking sub's plate amp to sum the L/R pre-out with the sub pre-out. The built-in low-pass filter in the plate amp could then be used to roll off the flanking subs above 100Hz as prescribed. To get the relative gains correct, the level of the overlapping upper range between the mains and flanking subs would be adjusted manually using measurements. The lower range of the subs (could be flanking and distant subs together) could then be set using Audyssey.
Thanks,
Darrell
| Re: flanking subs with small mains [message #75609 is a reply to message #75607] |
Fri, 22 February 2013 15:25   |
Keep in mind that the flanking sub / helper woofer approach does most of its thing between 80Hz and 200Hz. So if the mains can run to 80Hz, you can run helper woofers like I described and get as much benefit from them as flanking subs that are typically run deeper. Your sound processor can be configured to high-pass the mains (and the connected helper woofers) at 80Hz.
The only real distinction between what I would call flanking subs and helper woofers is low-frequency extension. Flanking subs are generally run as helper woofers but with deeper bass capability. They do the helper woofer part up high, mitigating the self-interference notches from nearest boundaries. Then down low they act as traditional subs, but of course only with whatever content is in the channel of the main speaker being flanked. This can assist the distributed subs in smoothing lower frequency room modes.
But in your case, I think you're saying you want to high-pass the mains around 80Hz. So I'd probably consider running helper woofers, and not expect deep bass from either the mains or the helper woofers. The helper woofers are still flanking the mains, smoothing the 80-200Hz range, but they're not subs. They're more like a 2.5-way speaker used from 80Hz up, where the second helper woofer is detached from the main cabinet, set a little bit beside, behind and below it.
Then run your LFE channel to a traditional subwoofer or an array of multisubs.
