Home » Audio » Thermionic Emissions » Duncan Amps PSUD
Duncan Amps PSUD [message #9768] Wed, 16 August 2006 13:16 Go to next message
I been practicing and things are getting better but I can't get a nice curve yet. On the graph. I get good voltages but a crummy graph. Any ideas would be appreciated.
Re: Duncan Amps PSUD [message #9769 is a reply to message #9768] Wed, 16 August 2006 17:05 Go to previous messageGo to next message
I'm curious. Could you post the power chain you're trying to simulate? Might be fun if we all work on it......Regards, Colin
Re: Duncan Amps PSUD [message #9771 is a reply to message #9769] Thu, 17 August 2006 08:03 Go to previous messageGo to next message
I would love to; how do I do that?
Re: Duncan Amps PSUD [message #9773 is a reply to message #9771] Thu, 17 August 2006 08:27 Go to previous messageGo to next message
1) Screen capture. Hit Alt+Print Screen at the same time. This captures the screen.
2) Open Paint or some other graphic program.
3) Paste screen capture into window
4) Save file
5) Upload file to host
6) Link host under "Optional Image URL" in ART forum
Re: Duncan Amps PSUD [message #9775 is a reply to message #9773] Thu, 17 August 2006 11:55 Go to previous messageGo to next message
I don't think I have any graphics programs on my PC. How would I get those?
Re: Duncan Amps PSUD [message #9776 is a reply to message #9775] Thu, 17 August 2006 13:42 Go to previous messageGo to next message
Do you have any image viewing programs? If I remember correctly, you are not running Windows. Is that correct?.....
Re: Duncan Amps PSUD [message #9777 is a reply to message #9776] Thu, 17 August 2006 14:57 Go to previous messageGo to next message
I have XP; the operating system you mean? I was able to post some photos back a few yrs but the photo hosting service died and that was the last time I found I could post pictures.
I am sure if I spent many hrs tracking down a service and learning to use it I could get it going; but is it worth the trouble? Posting PSUD results would be great except I am sure not many would bother to read them anyway. If I need to send a photo I just scan it. Other than that I havn't had a need to do this up until now.
Paint [message #9778 is a reply to message #9777] Thu, 17 August 2006 15:56 Go to previous messageGo to next message
XP should have loaded "Paint." Look under Start>All Programs>Accessories. You should be able to paste a screen shot to Paint's open window
For hosting, I use imageshack.us. It's free and generates all the host codes for you.....Colin
Re: Paint [message #9779 is a reply to message #9778] Thu, 17 August 2006 17:01 Go to previous messageGo to next message
Okay; so I have paint; how does the photo get onto the paintboard?
Re: Paint [message #9780 is a reply to message #9779] Thu, 17 August 2006 17:13 Go to previous messageGo to previous message
1) Open Paint
2) Open PSUD
3) In PSUD, do the simulation
4) Hit ALT+Print Screen, at the same time. This puts the screen shot on the virtual clipboard.
5) Switch to paint
6) Click on the Paint canvas
7) Under "edit" click paste
8) The screen shot should be on the screen. If screen shot is not on the screen, turn off "Num Lock" on numeric pad and repeat from step 4.
9) Once picture is on screen save and upload
Previous Topic: arent these..
Next Topic: Resistor Recommendations for DIY Power Amp
Current Time: Thu Oct 29 10:45:23 CDT 2026
