Home » Audio » Source » Keeping Vinyl Records in Top Shape
Keeping Vinyl Records in Top Shape [message #65551] Tue, 04 January 2011 11:05 Go to next message
Jorel is currently offline  Jorel
I inquired about buying vinyl records and its player on another thread. Now that I have an idea on what to buy, I would like to know the proper storage of these records for them to remain in top condition.
Re: Keeping Vinyl Records in Top Shape [message #65565 is a reply to message #65551] Tue, 04 January 2011 21:30 Go to previous messageGo to next message
*They will probably start warping at anything over 90 degrees.
*They sell plastic record sleeves that are about 25 bucks for like 50 of them I think. I like them and have all my records in them. You lose the paper feeling of flipping through them, but a spilled drink doesn't ruin the artwork. I like to write stuff on the plastic sleeves.
*they like being stored on their sides, not flat.
*I recommend plan old dish soap and a sponge, though you'll probably have to release the static charge this might build. They make brushes for that.
*The 1980's saw the release of really thin, tightly packed grooves called "dynaflex." Avoid these if at all possible. They will skip and warp easily and tend to have a thin range in my experience from being compressed.
Re: Keeping Vinyl Records in Top Shape [message #65602 is a reply to message #65565] Thu, 06 January 2011 20:11 Go to previous messageGo to next message
Adveser wrote on Tue, 04 January 2011 21:30
I never thought that vinyl records needed to be stored in this way. Why is it that we need to store the records on their sides? My grandfather stored like this with his records but I never bothered to ask.
Re: Keeping Vinyl Records in Top Shape [message #65606 is a reply to message #65602] Thu, 06 January 2011 21:50 Go to previous messageGo to next message
Jorel wrote on Thu, 06 January 2011 20:11
Ventilation. They will warp even at modest temperature if there is weight on them. Part of the record will hang with the force of gravity if stacked on top of each other.
Re: Keeping Vinyl Records in Top Shape [message #65621 is a reply to message #65606] Fri, 07 January 2011 10:19 Go to previous messageGo to next message
I might also suggest if you use the dish soap method of cleaning them to do a final rinse with distilled water (not deionized water) so as not to leave hard water deposits all over your albums. They also make small covers that will go over the labels so if you accidentally get that area wet they won't come off, or just be very careful to not get the label wet.
Re: Keeping Vinyl Records in Top Shape [message #65626 is a reply to message #65551] Fri, 07 January 2011 12:00 Go to previous messageGo to next message
Yeah, what Shane said. I'm from Florida and the whole concept of Hard Water goes over my head sometimes. Good advice Shane.
Re: Keeping Vinyl Records in Top Shape [message #65680 is a reply to message #65551] Thu, 13 January 2011 09:15 Go to previous messageGo to next message
Thanks a lot for the great advice. Is there a method of washing as not to touch the labels? What will happen when hard water deposits harden on the vinyl? If this accidentally happens, what is the best way to treat it?
Re: Keeping Vinyl Records in Top Shape [message #65698 is a reply to message #65680] Sat, 15 January 2011 14:52 Go to previous messageGo to next message
This is a basic manual cleaning system that many say works well. What you will find is that there are as many opinions of how to clean vinyl as there are people who listen to it.
Spin-Clean
Re: Keeping Vinyl Records in Top Shape [message #65752 is a reply to message #65698] Tue, 18 January 2011 19:37 Go to previous messageGo to next message
I will follow the guide on how to clean vinyl.
I remember a show in TV before and they've shown a vinyl in bad shape. It still plays good but I think it is just another player and not the real vinyl playing. Do you think a vinyl will still play well even when the shape is not flat any longer?
Re: Keeping Vinyl Records in Top Shape [message #65755 is a reply to message #65752] Tue, 18 January 2011 21:36 Go to previous messageGo to previous message
Depends on how warped the record is. I've seen some that had a little warp in them and didn't sound bad. Too much and that arm is going to be bouncing in the air and you'll be buying a new stylus. A record clamp can make a big difference if the record is not perfectly flat.
Previous Topic: Remembering
Next Topic: High Resolution Technologies' iStreamer
Current Time: Tue Oct 13 23:58:03 CDT 2026
