Home » Sponsored » Pi Speakers » 12PI plan or CAD ?
12PI plan or CAD ? [message #61195] Fri, 16 October 2009 15:52 Go to next message
cox-nox is currently offline  cox-nox
first hello everybody,
i just read this post on PSW:
http://srforums.prosoundweb.com/index.php/mv/msg/15490/141095/0/
i didn't know that 12PI was a diy project, i look over the forum but don't find the plan...
Re: 12PI plan or CAD ? [message #61196 is a reply to message #61195] Fri, 16 October 2009 20:18 Go to previous messageGo to next message
Yes, a very ambitious project, one that resulted in a patent for the cooling plug. I sought to improve upon the LABhorn, after some prompting from Tom Danley and Todd Michaels. I believe we accomplished this quite well, with increased durability, greater output, lower distortion and smoother response all from a horn only five inches wider than the LABhorn. If you want the plans, I'll send them to you. We also make flat pack kits and other parts available for sale.
Re: 12PI plan or CAD ? [message #61201 is a reply to message #61195] Sat, 17 October 2009 07:04 Go to previous messageGo to next message
thanks for the answer Wink
first i would like to see the plan(in mm pleaz) and study it a little beat...
Re: 12PI plan or CAD ? [message #61202 is a reply to message #61201] Sat, 17 October 2009 08:22 Go to previous messageGo to next message
You've got mail!
Re: 12PI plan or CAD ? [message #61280 is a reply to message #61196] Fri, 30 October 2009 11:22 Go to previous messageGo to next message
bitzo is currently offline  bitzo
Hi Wayne,
I see your great work on this cab, the spl plot is amazing.
I've some question about the cooling. The plate metal panel it's a great idea and plug too..but...are there some DIY option?
If I use a wood panel is heat too much for the driver?
Could you send me the plans? I want to make some simulation in akabak to get some plot about different way of stacking.
cheers, bitzo
www.unitedroots.it
Re: 12PI plan or CAD ? [message #61281 is a reply to message #61280] Fri, 30 October 2009 11:53 Go to previous messageGo to next message
You've got mail!
You can omit the cooling plug but thermal limits are then less than half what they are with the plug. When used at 30Hz and higher, the limiting factor is thermal, not mechanical, even if cooling plugs are used and most definitely without the plugs. There was some talk years ago that the LABhorn limit was mechanical, and this simply isn't the truth. Those guys were misinformed and fooling themselves. When you see them blown in the field, it's always voice coil burnout, literally melting the adhesive allowing the coil to unravel off the former. So the cooling plugs are cheap insurance against failure.
Re: 12PI plan or CAD ? [message #61284 is a reply to message #61281] Fri, 30 October 2009 12:39 Go to previous messageGo to next message
wow! fear and fire from this cab...
so what is the best way of stacking 4 of this cab? What about Vplating?
cheers, bitzo
www.unitedroots.it
Re: 12PI plan or CAD ? [message #61285 is a reply to message #61284] Fri, 30 October 2009 13:12 Go to previous messageGo to next message
Stacking is usually determined by the environment. One of the best arrangements is all four standing side by side in the center, another is two on two, on their sides. Put the mouths together and lay them on their sides. Then set another pair on top of that, again, mouths together. The cooling system will work even if there is no gap between cabinets but it obviously wouldn't hurt to have an inch or two gap between them.
Re: 12PI plan or CAD ? [message #61507 is a reply to message #61195] Sat, 05 December 2009 21:29 Go to previous messageGo to next message
NickP is currently offline  NickP
Hi Wayne,
I'm thinking about building a new sub design and interested in the 12pi. Can you send me the plans? I'm in the UK so a flat pack is not really a viable option.
Thanks a lot,
Nick Procktor
Re: 12PI plan or CAD ? [message #61508 is a reply to message #61507] Sun, 06 December 2009 09:29 Go to previous messageGo to previous message
You've got mail!
Previous Topic: insulation for the 2pi tower
Next Topic: 3 Pi Plans
Current Time: Sat Oct 24 20:30:09 CDT 2026
