Home » Audio » Silicon Valley » What's the longest solid-state amp that you've owned?
Re: What's the longest solid-state amp that you've owned? [message #99848 is a reply to message #99843] Tue, 06 October 2026 21:32 Go to previous message
Hi As a SS amp generally yes.  But I design ans build my own tube gear and I much prefar the sound.A picture of my current system.  There are 4 Oddblocks on either side of the tape recorder.  On the top right shelf with a wood case is one of my tube phono preamps.  Just below the Empire turntable under it and not really visible is my line stage preamp.  All my designs and have been posted eleswhere on the web (mostly in diyaudioprojects.com).  The tall speakers are Martin Logan ESLs.  Behind them in the corners are Altec Lansing home versions of the voice of the theater.  I use only the low frequency drivers as subs (awesome).  The second photo is of a stereo version of the amps with a modular SS preamp. Most of the projects have been published in Audio Express./forum/index.php?t=getfile&id=3616&private=0[img]/forum/index.php?t=getfile&id=3617&private=0[/img]
Previous Topic: Thinking about the Vitus SS-103, is it worth the price?
Current Time: Sun Nov 22 23:31:02 CST 2026
