Home » Audio » Thermionic Emissions » Buying Amps on eBay
Re: Buying Amps on eBay [message #99792 is a reply to message #69262] Mon, 14 September 2026 13:50 Go to previous message
Clint is currently offline  Clint
Yeah I’ve grabbed a few tube amps off eBay. Some were solid, a couple needed work pretty quick.
I would say that brand and specs only get you so far. I check the seller’s feedback first—lots of sales and good ratings in audio stuff helps. Then I stare at the photos. I want to see the insides if they’re showing them, the tubes, any obvious wear or junk. If the listing is sparse I just message the guy and ask what’s up with the tubes, if it’s been worked on, does it hum, any weird noises. Decent sellers usually reply.
Still a gamble though. Caps go bad, tubes get tired, stuff like that. I’ve had ones that looked perfect and still needed a re-cap once they showed up. So I usually figure I’ll spend a little more getting a tech to look it over, especially on older ones. If the price is too good I get suspicious.
Specs tell you the basics but the real sound comes down to condition and the tubes more than anything. I just try not to get burned and accept that sometimes you’re still fixing things.
Previous Topic: What are the common issues that you've experienced with using different tube amps?
Next Topic: Will there be a time when tube amps are rarely used?
Current Time: Thu Nov 19 08:24:37 CST 2026
