Home » Audio » Thermionic Emissions » Goodwill Amp
Re: It's a Baldwin Model 40 "orgasonic" [message #9979 is a reply to message #9978] Mon, 23 July 2007 08:18 Go to previous messageGo to previous message
Are you saying it's an amplifier from an electric organ? How does it sound? Have you hooked it up to a music source and speakers yet?
If it was designed to use speakers with a field coil, the field coil probably serves double duty as a power supply filter coil. Other than that, you can run the output through the output transformer to a fixed magnet speaker. Just be sure the B+ circuit path through the field coil is maintained using a separate coil or something.
Previous Topic: Transcendent Audio
Next Topic: Parafeed vs transformer coupled
Current Time: Fri Nov 06 11:40:42 CST 2026
