Home » Audio » Speaker » Do you feel excited having tall DIY speakers than commercially made ones?
Re: Do you feel excited having tall DIY speakers than commercially made ones? [message #99766 is a reply to message #99724] Mon, 07 September 2026 11:34 Go to previous message
George is currently offline  George
Rusty wrote on Sat, 22 August 2026 10:46
I'm kinda puzzled with what "parts" wear out with DIY speakers, anymore than commercial speakers. Capacitors, coils, resistors or speaker drivers? Many DIY speakers I've been familiar with usually use very good speaker drivers as well as the crossover components. And DIYr's tend to overbuild their cabinets to the commercial ones. About the only thing I can assume is that many people aren't DIY oriented is from cabinet construction and I guess sweat equity goes into building DIY speakers.
But for me, that was the compelling challenge. That and the cost to performance ratio. It's all good though in enjoying what the audio pursuit is.
I've seen a couple of pretty good DIY tall speakers. So, I don't get it when someone talks down on DIY speakers.
It always boils down to the amount of work put into building those speakers. Once done right, it should serve the test of time. Using quality speakers divers,capacitors and other parts to build speakers can make them last longer too.
Previous Topic: Screw Loose
Next Topic: Wearable speakers or headphones?
Current Time: Sun Nov 01 23:23:36 CST 2026
