Home » Audio » Speaker » Do you feel excited having tall DIY speakers than commercially made ones?
Re: Do you feel excited having tall DIY speakers than commercially made ones? [message #99727 is a reply to message #99724] Sat, 22 August 2026 20:40 Go to previous messageGo to previous message
I like both diy and commercial speakers.  For commercial I use Martin Logan ESLs.  Five tall and if you like the type of sound they produce hard to beat.  To boot they are sensitive as well not like some other un-named ones).  15 watts is really loud.  For Diy -sort of- I refurbished a set of Altec Lansing VOTs (home type) that had no drivers.  I used a new manufacture 30 cm woofer that was mode by Great Plains Audio that is identical to the originals.  I upgraded the tweeter midrange horn with a Radian 475 PB driveer on a Seos horn.  I used a self designed crossover. Sensitivity is huge so are the cabinets. I use only tube amps a preamps. /forum/index.php?t=getfile&id=3611&private=0
Previous Topic: Screw Loose
Next Topic: Wearable speakers or headphones?
Current Time: Sun Nov 01 23:23:35 CST 2026
