Home » Audio » Speaker » Do you feel excited having tall DIY speakers than commercially made ones?
Re: Do you feel excited having tall DIY speakers than commercially made ones? [message #99712 is a reply to message #99709] Thu, 20 August 2026 12:44 Go to previous messageGo to previous message
Hank is currently offline  Hank
Rusty wrote on Wed, 19 August 2026 16:53
I helped a friend build a pair of 2Pi Towers a couple of years back. They're tower speakers, with high sensitivity drivers. The build is a rectangular box and a rear port without a tube. Just the thickness of the mdf used for their construction. A very simple crossover. And they sound dynamite. My friend had been using a pair of Technics 2 way budget bookshelf speakers he'd had since a teenager. The transition to these was staggering.
I'd built a pair of Pi horn loaded bass reflex speakers years before that are BIG and sound BIG. I use tube and solid state amps with it. High sensitivity speakers have quenched my desire for fidelity.
/forum/index.php?t=getfile&id=3603&private=0
/forum/index.php?t=getfile&id=3604&private=0
They look stunning. Perfectly positioned and matches the wall color.
How much did you spend in total in assembling everything when you did a few years ago? Can you remember?
Previous Topic: Screw Loose
Next Topic: Wearable speakers or headphones?
Current Time: Sun Nov 01 23:24:15 CST 2026
