Home » Audio » Thermionic Emissions » What are the common issues that you've experienced with using different tube amps?
Re: What are the common issues that you've experienced with using different tube amps? [message #99643 is a reply to message #99541] Mon, 03 August 2026 19:50 Go to previous messageGo to previous message
Hank is currently offline  Hank
gofar99 wrote on Tue, 30 June 2026 20:46
Hi, I understand heat...it what AC is for as it is usually pretty warm in Arizona anyhow.  I have presently a quad of KT120 mono blocks powering my system.  Yes they do get warm.  The photo is from a while back but I think you will get the idea./forum/index.php?t=getfile&id=3594&private=0
Air-conditioners certainly fix that worry about hot temperature in the room. It's such a cool idea. How much did you spend when you purchased the mono blocks?
Previous Topic: Popular myths about tube amps
Next Topic: Buying Amps on eBay
Current Time: Fri Oct 23 18:56:59 CDT 2026
