Home » Audio » Room Acoustics » What material is the best for soundproofing?
Re: What material is the best for soundproofing? [message #99627 is a reply to message #97613] Wed, 29 July 2026 01:29 Go to previous message
Clint is currently offline  Clint
With my experience fixing noisy rooms, the best material that I would say has done the job for me quite alright is the mass loaded vinyl. I understand that others might have a different opinion in terms of which material works best, but I've never gone wrong using MLV to fix issues with noisy rooms.
I recently used in a new studio that my mentee started last two months and the result was excellent. All I did was use it in dozens of walls and cellings... the outcome was fantastic!
So, I will always recommend using MLV instead of other materials like foam panels or thick curtains that won't be able to block sound from moving through the walls. I bet you won't you don't want to have such an experience. I will always advise that you pair the MLV with proper installation and you will figure out the difference straight away. I have used this method in many rooms and assisted my friends in doing same and it has neve failed.
Previous Topic: Sound in basement
Next Topic: Room Mode Calculator
Current Time: Wed Nov 18 02:28:28 CST 2026
