Home » Audio » Group Build » New Projects
Re: New Projects [message #99592 is a reply to message #68423] Thu, 16 July 2026 09:21 Go to previous message
Hank is currently offline  Hank
gofar99 wrote on Fri, 01 July 2011 22:17
Hi All,  As promised, check out the phono preamp I posted in the Thermionic section.  Warm up your soldering irons every vinyl lover should try one.  Parts are off the shelf to hold the cost down and the biggest problem is layout and care in construction as it is a high gain device.
I've been following your works here, and you are doing great! Is there any new stuff in the block? Would want to follow up on progress.
Previous Topic: Planning on building a hifi rack, need suggestions.
Next Topic: How often do you have group builds?
Current Time: Fri Oct 23 15:50:49 CDT 2026
