Home » Audio » Measurement » Do you think Home Theatre Calibration services are worth the cost? (Ever hired one?)
Re: Do you think Home Theatre Calibration services are worth the cost? [message #99584 is a reply to message #99582] Mon, 13 July 2026 21:28 Go to previous messageGo to previous message
Hi, I didn't see this thread until now but I have a few thoughts.  The first one and possibly covered earlier is your system capable of being tweaked?  Second I have discovered a device from Behringer (a 2300 I believe it is in storage at present) that uses  a microphone at your listening spot and will deliver tones to the system. It has lots of presets to adjust each channel separately.  You can see what the effect is as you  do it and save the values internally. It will hold several sets  of settings. Also several HT amplifiers can do the same thing.  No need to spend $1000.  With that much money you can buy something that you can keep that will do the job for you.
Previous Topic: Measuring noise
Current Time: Wed Nov 04 14:32:40 CST 2026
