Home » Audio » Craftsmen » Under or On The Wall (Electrical Wirings)
Re: Under or On The Wall [message #99578 is a reply to message #89896] Sun, 12 July 2026 10:56 Go to previous message
Hank is currently offline  Hank
Groot wrote on Sun, 10 March 2019 10:29
I'm planning to redesign my room to accommodate a new set of speakers and a TV monitor. I will need an additional electrical outlet for these gadgets. Do you think an extension electrical cord will do the job or should I have a fixed electrical outlet in the walls?
If I were in your shoes, I would go with a fixed wall outlet that I could construct myself. I am never comfortable with going with an extension cord in such a situation because there are chances that the wires can overheat depending on the type of the power demands of your gadgets.
There is also that possibility that most extension cords won't last more than a year before it develops issues.
So, constructing a proper outlet is cleaner, safer, and appropriate for the long-term.
Are you going to DIY, or would you go with the option of hiring an electrician to do the job for you?
Previous Topic: Getting Started
Next Topic: AH-Fix-it
Current Time: Sun Oct 18 22:10:49 CDT 2026
