Home » Audio » Thermionic Emissions » What are the common issues that you've experienced with using different tube amps?
Re: What are the common issues that you've experienced with using different tube amps? [message #99541 is a reply to message #99515] Tue, 30 June 2026 20:46 Go to previous messageGo to previous message
Hi, I understand heat...it what AC is for as it is usually pretty warm in Arizona anyhow.  I have presently a quad of KT120 mono blocks powering my system.  Yes they do get warm.  The photo is from a while back but I think you will get the idea./forum/index.php?t=getfile&id=3594&private=0
Previous Topic: Popular myths about tube amps
Next Topic: Buying Amps on eBay
Current Time: Fri Oct 23 18:55:17 CDT 2026
