Home » Audio » Thermionic Emissions » What are the common issues that you've experienced with using different tube amps?
Re: What are the common issues that you've experienced with using different tube amps? [message #99510 is a reply to message #99505] Mon, 15 June 2026 14:48 Go to previous messageGo to previous message
Well I dunno. I feel like I get the best of both with tube & SS amps. As mentioned, I run the tube amps in cooler weather, so the heat isn't a problem then. Their like space heaters in a way. A friend of mine jokes that I could use them with a rotisserie above them. And then in summer months its the SS amp. The Hafler I have does tend to run warm if I use it a while. But not like the tube amps. I like the change up with certain aspects of the sound scape from either of the two types of amplifiers too.
Previous Topic: Popular myths about tube amps
Next Topic: Buying Amps on eBay
Current Time: Fri Oct 23 18:58:15 CDT 2026
