Home » Audio » Thermionic Emissions » What are the common issues that you've experienced with using different tube amps?
Re: What are the common issues that you've experienced with using different tube amps? [message #99505 is a reply to message #99486] Wed, 10 June 2026 13:38 Go to previous messageGo to previous message
Hank is currently offline  Hank
I truly understand how you feel with the heat that comes with tube amps. In fact, that was the main reason that I switched from using them years ago to focus on solid-state amps.
I was never comfortable in my room because of the heat till I got a small fan that was always on when I was using the tubes. So, maybe I suggest you get a fan that you can keep in the room that can make the room cooler. I don't bother about those issues anymore because I run solid-state amps, and they give less drama, unlike tubes.
Previous Topic: Popular myths about tube amps
Next Topic: Buying Amps on eBay
Current Time: Fri Oct 23 18:57:31 CDT 2026
