Home » Audio » Silicon Valley » What's your preferred solid-state amp now? (Which brand serves you better at the moment?)
Re: What's your preferred solid-state amp now? [message #99460 is a reply to message #99424] Mon, 01 June 2026 23:58 Go to previous messageGo to previous message
Hank is currently offline  Hank
Kurt wrote on Wed, 20 May 2026 23:58
I've got the Klipsch RF-7 floorstanders, and the one amp that I've used on it for a while now is the Yamaha A-S220.
I've made use of the Yamaha A-S2200 most times as it perfectly fits the speakers. The bass and the highs don't get harsh while in use, and for the times that I've used it, I've not had any major complaints on it.
As one who really likes tube amps, I also make use of the Rogue Audio Sphinx V3, and the experience of using it has been pretty awesome. It doesn't cost much to maintain. That is the main reason that I picked it
Have you used any of the amps? If yes, what has been your personal experience on them?
The main point of amps is finding the right one that fits your speakers. It can be disheartening figuring out that the one you purchased never synchronised with the speakers you intend using it on. So, if the Yamaha A-S2200 works pretty good on your Klipsch speakers, then I don't see any need making a change.
Previous Topic: Which is Better, Tube Amps or Solid-State Amps?
Next Topic: Power FETs
Current Time: Sun Nov 22 07:08:04 CST 2026
