Home » Sponsored » Pi Speakers » Request for Four Pi plan
Re: Request for Four Pi plan [message #99441 is a reply to message #99438] Mon, 25 May 2026 21:41 Go to previous message
Is there any way you can attach a thinner front to your 18mm baffle?  Maybe a small 9mm thick panel?  If you do that, you can essentially build the cabinet with exact dimensions shown in the designs, and simply glue an extra 9mm panel in front.  That will also allow you to route the midwoofer and waveguide/horn mounting surfaces to provide flush mounting.  It's extra work, but it's attractive and it's not too hard - watch some videos showing the process.
Also, be careful that the port duct is 25.4cm from the front edge of the baffle to the edge on the inside of the box.  The total path length is 25.4cm.
Previous Topic: Interested in corner horn plans
Next Topic: 4Pi plans
Current Time: Thu Oct 22 14:43:26 CDT 2026
