Home » Sponsored » Pi Speakers » Request for Four Pi plan
Re: Request for Four Pi plan [message #99438 is a reply to message #99437] Mon, 25 May 2026 08:20 Go to previous messageGo to previous message
amigo is currently offline  amigo
Dear Wayne,
As you advised, I fixed the dimensions according to the plan. However, since we use the metric system here, 3/4"T (~19mmT) is unavailable, and only 18mmT plywood is possible. Therefore, I aligned the outer dimensions of the enclosure with the plan. And, taking this opportunity to reconsider, I am considering joining two 18mmT plywood panels together for the front baffle. As you have mentioned several times, this has the disadvantage of being heavier, but I think it will be easier for me to work with given my limited woodworking skills. So, the plan is to align the rear panel of the two baffle panels with the plan dimensions and attach the front panel to the front of the box. Is aligning the dimensions in this way the correct method to comply with the plan?
Regards, Chang-Hee
Previous Topic: Interested in corner horn plans
Next Topic: 4Pi plans
Current Time: Thu Oct 22 14:45:25 CDT 2026
