Home » Audio » Home Theater » What's your preferred speaker for your home theatre device? (Which speakers do you like using in your home theatre or the ones you would recommend?)
Re: What's your preferred speaker for your home theatre device? [message #99433 is a reply to message #98833] Sat, 23 May 2026 14:44 Go to previous messageGo to previous message
Kurt is currently offline  Kurt
I think making the right choice of speakers should first of all be about the sound quality, price vs. value, and the space that is in your place and not mostly about popularity even though it is a factor that shows many are using a particular brand.
I've got the Klipsch RF-7 III floorstanders in my place, and the whole audio experience has been fantastic. You can set up a complete system around them like I did using Klipsch RP-504C II center for voices, Klipsch SPL-120 for bass and RP-502S II surrounds for effects.
This setup can work greatly for both music and movie moments, giving you that cinematic feeling if you got the room treatment right.
The only challenge you are going to have with this setup is whether you've got enough space at your place. If you've got a limited space, maybe you can check Sonos Arc Ultra because it can fit into smaller rooms unlike the Klipsch RF-7 floorstanders.
Previous Topic: Improving the home theater
Next Topic: Curved Televisions
Current Time: Wed Nov 25 18:01:45 CST 2026
