Home » Audio » Thermionic Emissions » Popular myths about tube amps (Which One surprises you the most?)
Re: Popular myths about tube amps [message #99403 is a reply to message #99398] Sun, 10 May 2026 23:44 Go to previous messageGo to previous message
I for one will never use a SS amplifier (or preamplifier). It is all
tube for me except for the dac. There are just inherent problems with
SS that cannot be solved.
Tubes designs are a completely different story. I have described some of
the inherent problems with SS in another string called "Solid State vs
Vacuum Amps", in this Tube subforum.
I finished up my phono stage (except somewhat haywire look) and I do find
some LPs superior but costly, to high rez ss dacs).
Cheers
steve
Previous Topic: Tube amps on PC.
Next Topic: What are the common issues that you've experienced with using different tube amps?
Current Time: Fri Oct 23 19:53:38 CDT 2026
