Home » Audio » Pro Sound » Should I blow the budget on getting expensive cables? (Does it improve sound production?)
Re: Should I blow the budget on getting expensive cables? [message #99390 is a reply to message #99370] Mon, 04 May 2026 10:06 Go to previous messageGo to previous message
Clint is currently offline  Clint
Hank wrote on Sun, 26 April 2026 14:27
See, I've got to be honest with you and speaking from experience, using cheap, well-built cables sound just neat and dynamic.
So, using an expensive cables rarely make any big upgrade in sound quality. The big differences are noticed with upgrades on amps, speakers and in some cases, room treatments.
For that reason, I won't advise that you spend above your budget getting expensive cables when you can spend that on upgrading the speakers, for example.
Thank you for your input. I will be reconsidering my plans of changing the cables to an expensive one. Possibly, I should work on making upgrades on the amps that I use at the studio because it's been a long time overdue!
Previous Topic: Best Headphones?
Next Topic: Software to visualize sound waves
Current Time: Fri Oct 30 07:24:14 CDT 2026
