Home » Audio » Pro Sound » Should I blow the budget on getting expensive cables? (Does it improve sound production?)
Re: Should I blow the budget on getting expensive cables? [message #99370 is a reply to message #99355] Sun, 26 April 2026 14:27 Go to previous messageGo to previous message
Hank is currently offline  Hank
See, I've got to be honest with you and speaking from experience, using cheap, well-built cables sound just neat and dynamic.
So, using an expensive cables rarely make any big upgrade in sound quality. The big differences are noticed with upgrades on amps, speakers and in some cases, room treatments.
For that reason, I won't advise that you spend above your budget getting expensive cables when you can spend that on upgrading the speakers, for example.
Previous Topic: Best Headphones?
Next Topic: Software to visualize sound waves
Current Time: Fri Oct 30 07:23:51 CDT 2026
