Home » Audio » Thermionic Emissions » Popular myths about tube amps (Which One surprises you the most?)
Re: Popular myths about tube amps [message #99364 is a reply to message #99169] Thu, 23 April 2026 10:01 Go to previous messageGo to previous message
Hi, it is bogus.  (I am finally back see Tower) I have had a total of three listeners sell off their expensive SS amps (two were Mark Ls that ran over $11,000) for a pair of Oddwatts.  Tube amps are not better or worse that SS ones.  If well designed both will do the job well.  To be sure there some speaker that work better on one kind or the other.  I would not use many tube amps on current hungry speakers and would probably not use SS ones on many of the vintage high sensitivity speakers.  It is sort of like putting gas in a vehicle.  All types will generally work but some may work better in certain vehicles.
Previous Topic: Tube amps on PC.
Next Topic: What are the common issues that you've experienced with using different tube amps?
Current Time: Fri Oct 23 19:54:45 CDT 2026
