Home » Audio » Pro Sound » Should I blow the budget on getting expensive cables? (Does it improve sound production?)
Should I blow the budget on getting expensive cables? [message #99355] Thu, 16 April 2026 23:54 Go to previous message
Clint is currently offline  Clint
I've been wondering if those expensive cables affect sound production in a way that the normal cables can't? I've seen some ads concerning those expensive cables, and I am considering blowing my budget to get those.
Do you think it is a wise idea to do so? What has been your experience with using expensive cables? Is there a big difference between them and the normal ones?
Previous Topic: Best Headphones?
Next Topic: Software to visualize sound waves
Current Time: Tue Oct 20 12:38:23 CDT 2026
