| Re: Home Theater for the Outdoors [message #99353 is a reply to message #94911] |
Wed, 15 April 2026 22:59  |
Prince
Messages: 115 Registered: September 2025
Viscount |
Wayne Parham wrote on Tue, 14 December 2021 09:15
Actually, outdoors, one thing in your benefit is there are no room modes. And if your setup is far enough away from buildings, then there are no early reflections. That's a significant advantage, acoustically. Of course, you'll probably need more power because space is not constrained. But that's not too difficult to provide.
Seems to me the biggest issues are the elements to deal with, like the weather, insects, etc. I assume the goal would be limited to night viewing. Might have noise problems, either from outside interfering with your viewers or from your system disturbing neighbors or violating local restrictions in some way. So I think the biggest issues aren't technical audio or video matters, but rather they are problems of regulation, interference, convenience and level of comfort.
That's the thing with setting up home theatre outside. One should make enquiries to be sure that they are not breaking any type of rule with what they plan to do. I won't want to be addressing a lawsuit simply because I gathered families and friends just to enjoy ourselves.
