Home » Audio » Pro Sound » Is the difference in sound quality all in our head?
Re: Is the difference in sound quality all in our head? [message #99331 is a reply to message #89517] Tue, 07 April 2026 21:18 Go to previous messageGo to previous message
Clint is currently offline  Clint
Wayne Parham wrote on Mon, 07 January 2019 17:28
I've studied this for my entire adult life.
My conclusions are that:
1.  We can measure things that we cannot hear.
2.  Some of the things we can measure matter more than others.
So I can reach a few conclusions from this:
1.  If I cannot measure a difference, then I certainly cannot hear a difference.
2.  If I can measure a difference, then I may or may not be able to hear a difference.
3.  To tell how audible a measurable difference makes, one can employ subjective blind listening tests.  That will help determine what is audible, and by how much.
I strongly agree with your point 3 that a properly controlled blind test will go a long way in bridging the gap between perception and measurement.
Non blinded tests are often biased as a result of expectations arsing from visual cues, prices of equipments and even equipment brand choices
I am not saying that blind tests are the ultimate method here, but it is a far better option than the visual testing method.
Previous Topic: Piano Applications on the Phone
Next Topic: Earphone Recommendations?
Current Time: Fri Nov 27 08:25:25 CST 2026
