Home » Audio » Source » Ordered a Schiit Mimir DAC (Will test)
Re: Ordered a Schiit Mimir DAC [message #99330 is a reply to message #99290] Tue, 07 April 2026 19:25 Go to previous messageGo to previous message
positron wrote on Mon, 16 March 2026 19:35
Wayne Parham wrote on Fri, 13 March 2026 12:30
That's really awesome!
I've heard nothing but good things about that company and its products.
Hi Wayne,
Yes, absolutely. I should have previously posted another thought I
have been mulling over.
Since the recording equipment is half the
electronics, how do I know how close to butting up against
the absolute maximum sonic quality of the recording components?
I think I am quite close after adding the all copper single
ended output jacks with Jenalabs wire increased naturalness
a little, but noticeable. Interestingly,
I just made another upgrade, and the sound improvement was not
as apparent. I think I am really really close now, as the sonic
improvement, naturalness should have been larger.
I don't think I am going to try anything else, at least for awhile.
cheers
pos
I guess the definition "for a while" was not too long for me.  :)
I am working with the power supply and improved the sonics,
slightly; cleaner across the entire audio band. Higher quality
audio grade capacitors, voltage rating etc, makes a difference.
Cheers
pos
Previous Topic: Oiling Turntable Bearings
Next Topic: Digital looks so simple, sometimes I miss the vinyl ritual
Current Time: Thu Nov 12 22:35:06 CST 2026
