Home » Sponsored » Pi Speakers » 4pi: Cabinetmaker's build
4pi: Cabinetmaker's build [message #99291] Mon, 16 March 2026 21:35 Go to previous message
dustboy is currently offline  dustboy
4pi parts are on order JBL 2226/DE250 (and backorder, in the case of the DE250-8's) and in the mean time I'm starting to work out the details.
I own a custom cabinet shop with 5x10 CNC router and edgebander, so building boxes is kind of my thing. But doing the engineering of building a speaker is way beyond my mental capacity so I'm glad to have found this design. I've built several kits before including Zaph Audio 5.2 and Adire Audio MTM.
I don't want to mess with success so I'll be sticking with the script for the most part.
-Would it be a bad idea to fillet the mouth of the port with a 3D printed flare? Or 3DP the entire port with flares at both ends? Presumably sharp outside corners produce turbulence and most ports I've seen have this feature. Would I want to change the length of the port if I do this?
-I have 2+ sheets of A1 MDF with a walnut veneer that are very nice and even better, free. I think most folks are using 18mm or thicker baltic birch these days, so I'll plan for more internal bracing. What is the intended enclosure volume? For whatever volume I displace internally I'll need to add to the total enclosure volume, yes? Which outer dimension is preferable to modify?
-I'm considering an inset baffle to allow a removable cloth grille panel to set flush.
-I will probably integrate a base, maybe some nice hardwood legs and try to make the speaker a bit less boxy looking.
Previous Topic: 4Pi plans
Next Topic: 4 Pi build Ferrari Red
Current Time: Tue Nov 03 23:44:12 CST 2026
