Home » Audio » Craftsmen » Refurbishing An Old Radio / Turntable
Re: Refurbishing An Old Radio / Turntable [message #99238 is a reply to message #99121] Thu, 19 February 2026 07:05 Go to previous message
Hank is currently offline  Hank
Prince wrote on Tue, 02 December 2025 12:28
I have heard about a couple of speciality stores and online sites whose work is selling parts that can assist in restoring vintage audio equipment such as turntables.
I would have recommended stores such as Lowe's, but last I checked, they deal mainly in general hardware and electronics like wires.
Turntable Medic is one that I believe can be of help as they specialise in sourcing parts and repairing vintage turntables, changers, and console stereos.
Ebay is another online marketplace that you can check out, but you need to do a specific search for the vintage turntable part/model that you are looking for.
If you are not too confident to buy online, you should use the Google Map to search for "vintage audio repairs close by" and hopefully the map can pop up with some choices of physical stores that you should look at to see if they have the parts that you need.
The best decision for anyone who cares to listen is to visit a physical store. You are able to make choices on the material that you need to revive your vintage turntable. Also, talking with the salesperson can go a long way since they have an idea of which brand will fit into what anyone wants to do.
Previous Topic: Expenses and other factors
Next Topic: DIY audio gear vs. visual gear
Current Time: Wed Nov 04 22:27:35 CST 2026
