Home » Audio » Home Theater » TV Box Recommendations
Re: TV Box Recommendations [message #99112 is a reply to message #93980] Wed, 26 November 2025 03:47 Go to previous message
Prince is currently offline  Prince
There are a lot of TV boxes that you can get for both movie and gaming experiences. The one that  I am currently using at the moment is the Onn 4k Pro and it has served me pretty well for a while now. The good thing about the onn 4k Pro is that you won't have to break the bank before you can be able to get this box which makes it my top recommended TV box.
The other ones that you can check out are NVIDIA Shield TV Pro, TiVo Stream 4K and the Formuler Z11 Pro Max. I've seen a couple of reviews on it, but you should check them yourself if you are planning to get any of these.
Previous Topic: Your fantasy home theater room
Next Topic: Good enough smart TV
Current Time: Thu Nov 05 13:35:41 CST 2026
