Home » Audio » Silicon Valley » Crackling
Re: Crackling [message #99100 is a reply to message #87391] Tue, 18 November 2025 23:42 Go to previous message
Becky is currently offline  Becky
Honestly, it might be something simple, but it really depends on what’s causing the crackling. A lot of amps start doing that when a part inside gets old, like a dirty pot, a loose connection, or something heating up after a few minutes. Sometimes just cleaning the knobs with contact cleaner can help, but other times it’s more of an internal issue.
Since it starts after the amp warms up, that usually means a part inside isn’t super happy anymore. You could pop it open and look for dust or loose wires if you’re comfortable, but if not, it might be safer to get someone to check it. I’d hate for you to try fixing it and make things worse.
If you really wanna use it again though, it’s definitely worth trying a basic cleaning first.
Previous Topic: Tubes versus Transistors
Next Topic: Do you think getting a customised solid-state amp is a waste of money?
Current Time: Fri Oct 23 18:58:09 CDT 2026
