Home » Audio » General » Amp choices for multi-amp config
Re: Amp choices for multi-amp config [message #990 is a reply to message #988] Mon, 18 October 2004 17:33 Go to previous messageGo to previous message
GarMan; We seem to be asking the same things. What I have heard is that the amps have critical parameters that must be similar in order to provide acceptable matching. Because there are so many variables it is best to use duplicate amps for each channel. Otherwise it is a crap shoot whether it will work. Why would the SE amp have such a narrow response band? The transformers must be inadequate or the circuit is deliberately rolled off in order to prevent feedback runaway. Frank Van Alstine deals with this in his articles. That is why he rolls off the ST 70 Dyna in his mod circuit. It is easy reading and very informative. I am using two chip amps with pretty good results. What I would like to know is how to incorporate a EQ. feature in the crossover, like the one in Waynes xovers. J.R.
Previous Topic: AR Turntable website unveiled
Next Topic: !!! Woodstock 25,000th Post Contest !!!
Current Time: Fri Nov 27 04:34:36 CST 2026
