Home » Sponsored » Pi Speakers » Compact version of 6Pi / 7Pi (Choosing between 6Pi and 7Pi and wife compatible modifications)
Re: Compact version of 6Pi / 7Pi [message #98807 is a reply to message #98806] Sat, 09 August 2025 23:33 Go to previous messageGo to previous message
So glad you got the 2226H drivers!  They are awesome!
The original seven Pi cabinet actually used a slightly larger wood horn, which had additional mouth radiusing to combat waistbanding.
The H290C isn't too bad in this regard, as you can see in the measurements:
Still, it benefits from the baffle on the three Pi and four Pi speakers, which reduces waistbanding without the additional mouth radiusing.  It would be even better if radiused and mounted on a baffle, but the trade-off is that the extra radiusing increases vertical distance between sound sources, bringing the vertical nulls closer together.
Personally, I would rather have the waistbanding than the vertical nulls too close together.  But I digress.
In your case, you have a design that adds a little extra baffling where the tweeter will mount.  None in the vertical, so I'm not sure how much it will help in the vertical plane but I suspect it will help a little in the horizontal.  So that's why I would do it if I were contemplating your mods.
Previous Topic: JBL 2226H question
Next Topic: 2 Pi tower plan request
Current Time: Thu Oct 22 15:18:34 CDT 2026
