Home » Sponsored » Pi Speakers » Ten happy years with the 3pi... Time for the Pi 3 subs!
Re: Ten happy years with the 3pi... Time for the Pi 3 subs! [message #98486 is a reply to message #98484] Fri, 25 April 2025 11:41 Go to previous messageGo to previous message
I'll send plans in a separate email.
Sounds to me like you have the right equipment to build an excellent sound system!
I think you are right though - basshorns, when used indoors, are best used as distributed multisubs.  So your placing them asymmetrically in the room would be a Geddes multisub configuration.  Very good.  Send them the LFE channel, or an all-channel summed signal with steep 4th-order low-pass, no higher than 80Hz.
Flanking subs are an excellent way to augment this arrangement, for all the reasons attributed to flanking subs - They provide baffle-step correction for the mains, mitigate SBIR and higher frequency room modes and provide additional extension.
Your basshorns provide more than adequate extension, I expect.  But it is probably somewhat detached from the mains.  By adding flanking subs, you'll blend them together much better.
Each flanking sub needs a low-passed copy of the signal sent to the main speaker it is flanking.  The low-pass slope is generally pretty "gentle" - I find second-order at 100Hz generally works well.
Previous Topic: The Intellectual People Podcast: Pi Speakers
Next Topic: 1 PI vent
Current Time: Tue Oct 20 12:38:38 CDT 2026
