Home » Audio » Thermionic Emissions » DH rectifier connection
Re: DH rectifier connection [message #9847 is a reply to message #9846] Thu, 26 October 2006 21:39 Go to previous message
Yes, you are correct. If your heater winding has a CT, you can tap your B+ from it.
I use pin 8, then if I want to switch to an indirectly heated rectifier you have a direct connection to the cathode…John
Previous Topic: Trannie DCR's
Next Topic: Re: Counterpoint SA-7 Schematic Needed
Current Time: Fri Nov 06 11:25:22 CST 2026
