Home » Audio » Thermionic Emissions » 6N11 vs 6922, E88CC, and 6DJ8 tubes
| Re: 6N11 vs 6922, E88CC, and 6DJ8 tubes [message #98423 is a reply to message #98322] |
Mon, 07 April 2025 19:04  |
positron
Messages: 164 Registered: May 2020
Master |
Hi Kasper,
Just a thought, I have been performing some longevity testing
of the JJ E88cc tube for longevity by reducing the filament
voltage. I wanted to determine what causes deterioration of
this particular tube.
One can typically assume a major player might be gas, some to
poisoning/impurities of the cathode/sleeve materials, some due
to cathode temperature, or a combo of the above.
I found with the JJ brand, it is Mainly due to cathode temperature.
After nearly a 1,000 hrs, at 5.8 volts, approximately 9 ma, there
has only been a 1-1.5% lowering of cathode current.
(My audio buddy's sp-3 preamp has filament voltage so low that it is
difficult to see a red cathode.)
Just a thought, you may already be doing this already.
A little tidbit for newbies about my decades research in the lab.
I hope this will help.
I exclusively use the JJ E88cc small signal tube in all my components
due to its incredibly low HD, some 19db less than any other tube
(2 volts rms output, -79db without negative feedback) and
incredibly accurate/natural sound. This assumes accurate and proper
size parts are used.
I once designed a PP circuit achieving 200 volts P-P signal output
at 0,05% measured harmonic distortion. (It depends upon the circuit
and cathode current used.)
I only wished the JJ would last longer; now it does with 5.8 filament
volts.
I have tried many many NOS tube types and this tube was sonically
superior across the entire audio band. I have many NOS tubes, but
never use them, which are now in the parts box.
Anyway, just some thoughts that might someone out there.
cheers
pos
By: gofar99 on Tue, 04 February 2025 19:55
By: gofar99 on Sat, 08 February 2025 20:01
By: positron on Mon, 07 April 2025 19:04
Current Time: Wed Oct 28 10:03:56 CDT 2026
