Home » Sponsored » Pi Speakers » 3 Pi build
Re: 3 Pi build [message #98258 is a reply to message #98255] Fri, 17 January 2025 10:45 Go to previous messageGo to previous message
When I helped a friend build a pair of 2Pi tower speakers using MDF. We found that veneer to cover front, top & sides would be more expensive than thin solid wood. We glued up for width and used wood glue to apply on to the MDF. I'd done that with my own speakers and it's stood up to the test of time. Also using water based polyurethane used for flooring helps with humidity. And where I live in the summer is very humid. Just an option among many others for you to figure on.
Previous Topic: Waveguide mistake
Next Topic: Happy Pi Day!
Current Time: Thu Nov 05 12:58:32 CST 2026
