Home » Sponsored » Pi Speakers » 3 Pi build
Re: 3 Pi build [message #98232 is a reply to message #98231] Sun, 05 January 2025 09:53 Go to previous messageGo to previous message
I often use 18mm Baltic Birch. When doing so, the main thing to consider is port length. The effects from the minor change of internal displacement are small, so I am not as concerned about that as the port length. The port needs to remain 63.5mm. It can be off by a millimeter or so either way, but no more.
When making the port with 18mm stock, cut three 100mm squares. Plane one of those down to 9mm thickness. Glue all three - two 18mm thick and one 9mm thick - squares onto your baffle, centered where the port hole will be cut. Glue and clamp them in place. And then use a 2-1/2" hole cutter to drill the port hole through the baffle and port blocks. Something like this:
That will create a port that's 63mm diameter and 63mm long.
Previous Topic: Waveguide mistake
Next Topic: Happy Pi Day!
Current Time: Thu Nov 05 13:55:23 CST 2026
