Home » Audio » Pro Sound » Software to visualize sound waves
Re: Software to visualize sound waves [message #98195 is a reply to message #98172] Wed, 01 January 2025 17:57 Go to previous messageGo to previous message
gofar99 wrote on Sun, 29 December 2024 20:55
I suspect that there might be some software out there that would do exactly what you want but I don't know of any. Anyone out there with some ideas on what seems a very worthy project?
It's a very sweet idea, leot55. You could use something like WavePad or Sonic Visualiser to create your artwork. Or, how do you feel about buying your gift, instead of making it yourself? I ask because Uncommon Goods has a seller that makes custom made song art. Check it out and see if it'll work for you.
https://www.uncommongoods.com/product/custom-song-wall-art/531760000002
Previous Topic: Should I blow the budget on getting expensive cables?
Next Topic: Is room treatment a must for bedroom producers?
Current Time: Sun Sep 13 17:14:56 CDT 2026
