Home » Audio » Craftsmen » Modular Build Aids
Re: Modular Build Aids [message #98126 is a reply to message #98124] Sat, 14 December 2024 20:09 Go to previous message
Hi, I often find that many projects use the same basic building blocks, so why not build them as separate pieces to use in the design of new projects. I just completed one such project. The active part of the all tube phono preamp is pretty much fixed and unchanging. Two versions only and the layout is the same, just a change in impedance of some sections. As far as I can tell both are so similar that someone listening could not tell the difference. Some subtle measurements only. So the power supply is the one area that I have focused a lot of time on. Way back in the early days I could create a wonderful device that hummed like a bumble bee. S/N at most of 50 dbv. Since then I have experimented with numerous designs. I have a "magic" number in my head of -90dbv. I want all my designs to reach that level. Simple for solid state ones, hard for tube ones. It took a lot of comparative testing on power supply designs to get the phono preamp there. I optimized ones for layout etc I can now get -92dbv. It requires careful tube selection and critical component placement and so on. If just assembled with some care (not excessive like mine) you can get -87 dbv. For those that don't know how dbvs work that is really really quiet. My fridge three rooms away and around two corners is a lot louder. Anyhow I digress. With a test set made up to test and compare all the power supply modules I was able to find what I figure is the very best combination. I was surprised by some things. The what I called "nearly as good" one has a rather simple power supply. I would say it is about 90-95% as good overall as the best one. Adding various additional components (to filter, regulate, chokes and so on) did not matter much. The best one is more complicated and deviates from that one with use of a FET capacitor multiplier, poly filter caps and so forth. A less fanatical user than I am would find it quite excellent. (as most folks know I hate hum and noise...if I can hear it or measure it then it is too much) My preamp now is limited by the internal noise of the tubes. I refuse to use negative feedback on it to cut that down as I feel that part of its magical sound is because there is only class A amplification with no NFB. NFB has its place to be sure but in designs that don't have nearly unlimited gain and bandwidth I believe it subtly alters the sound. IC designs need it and it is fine there. So with the preamp by being able to swap in and out the modules I determined the best combination. What is my next project...don't know yet.
/forum/index.php?t=getfile&id=3487&private=0
/forum/index.php?t=getfile&id=3488&private=0
Previous Topic: SMPS Trick
Next Topic: 1942 Ducati Radiogram
Current Time: Thu Nov 05 13:29:05 CST 2026
