Home » Audio » Source » to RIAA or not
Re: to RIAA or not [message #97937 is a reply to message #97934] Thu, 08 August 2024 21:25 Go to previous messageGo to previous message
Hi, I suspect it does that. I have a number of ADCs and DACs plus lots of software to fool around with. A quick check of Audacity indicated it was easy to create a RIAA eq. I intend to try feeding directly from a cartridge into a SIIG ADC and then save as a wave file at 34/96. Using that in Audacity apply the eq and adjust the level as needed. It would seem to be a way to do it. Dynamic range on the SIIG is 108 so it should be adequate. More to follow....
Previous Topic: Unexpected upgrade
Next Topic: Ethernet and USB Cable Comparisons
Current Time: Wed Nov 04 16:34:44 CST 2026
