Home » Audio » Thermionic Emissions » Sonic Difference between New Tung Sol 6550 vs KT120 vs KKT150 (Do they sound exactly alike?)
Re: Sonic Difference between New Tung Sol 6550 vs KT120 vs KKT150 [message #97908 is a reply to message #97906] Tue, 23 July 2024 22:41 Go to previous messageGo to previous message
gofar99 wrote on Tue, 23 July 2024 21:52
A can of worms. I find the JJ KT88s to last forever. The ones in my original amps (2009) are still fine. I run them in class A at 85% dissipation U/L mode. I do the same with KT120s in the bigger amps. None have ever failed. YMMV as always. There was a bad batch of TS KT120s about 6 years back. They would red plate at less than 50% dissipation. Since then I have not heard of any problems from folks using them. Now I use different settings in my main amps (don't need the power)I personally like the KT120s in U/L class A set at 62ma each and 450 B+ with an 8K load. It is really a sweet spot and produces the best sound of all the tube combinations I tried. A fairly close second is running them at 135ma and 500 B+ into a 4K load. Low level output is nearly in the distortion range of preamps. For an amp that uses essentially no NFB (2.5db above audio at 35KHZ for stability) a 0.1% distortion at 1watt makes for a really special sound. I have never tried the 6550 though. Everything from KT77 to EL34. Several brands all do seem to have a sonic signatures that are (IMO) likely hidden in most amps by the use of fairly large amounts of NFB. All Oddwatts (3 watt to 45 per ch) will run fine without any. I just wanted to avoid anything that might excite a 70KHZ resonance that is common to the configuration and selected components.
Thanks for the heads up on the KT120 problem and it being fixed
Bruce. I idle the TS 6550s and JJs at ~68ma. or so, so we are
pretty close.
I was able to test my monoblocks via specialized listening tests
and with the new Tung Sol 6550 sounds extremely accurate compared
to the input signal.
I need the TS KT120 to be as descent as their 6550s. I have several
other quads that did not cut the mustard, just sitting. Hate to
have the KT120s in the same boat, money lost.
I am hoping some others might have compared the two TS tubes in
the same system since the tubes have similar specs, except the
plate dissipation.
cheers
pos
Previous Topic: Class A, AB1, B, C Operation/Modes
Next Topic: The Bendix G15
Current Time: Wed Oct 28 10:53:32 CDT 2026
