gofar99 Messages: 2060 Registered: May 2010 Location: Southern Arizona
I contacted them (OPPO) quick responses good diagnostics and eventually a reasonable cost. it turns out that my played had to be sent in as it failed the diagnostics. SO it is on the way. For a flat fee they will fix it and return it. It could be simple and could be a lot more. I looked inside and decided if it wasn't a loose connector (many ribbon ones) then even with all the gear I have there were no user fixable parts inside. I'll up date every one when it gets back
