Home » Audio » Thermionic Emissions » PS Transformers
Re: PS Transformers [message #9751 is a reply to message #9750] Thu, 03 August 2006 09:51 Go to previous messageGo to previous message
Please; I understood where you are coming from in the post and appreciate it. I saw nothing to indicate anything but a helpfull tone. And as I said you are right on the money regarding that advice. In fact I believe I might have indicated I had a used trans I was considering so your point is well taken.
So; I must forget the effect DSR has on the filter and concentrate on measuring what I have and computing what I can do with that? Is that a good way to put it?
Yes it is hot here too; 99 deg. We had a brownout last night and I had to spend a few hours in the bar with the wife and AC. I don't normally do that during the week much; but I should.
Previous Topic: Filament Ratings
Next Topic: Fiament choke and filter scheme???
Current Time: Fri Nov 27 10:31:53 CST 2026
