Home » Audio » Thermionic Emissions » PS Transformers
Re: PS Transformers [message #9736 is a reply to message #9735] Fri, 28 July 2006 16:12 Go to previous messageGo to previous message
Well that would be the obvious and proper way to go about designing except how would I listen to it? I would have to build a amplifier and driver circuit then plug the PS into it and hope for the best I guess. A good learning experience except if it doesn't sound good; then a very expensive learning experience. Yet right here we have knowledgable designers who could pave the way so to speak.
Yes; of course my design skills are rudimentary; but why then do some people say use low DCR and some say High DCR on the secondaries? And one designer says you must find the off-load voltage to properly utilise the transformer. So each unit must be tested.
I have a couple PT's on hand; but not the ability to test each one for it's parameters.
So I expose my lack of design skills; can you surf? Or play golf and shoot in the low nineties? I'll play you one on one half-court, no blood no foul .
Previous Topic: Filament Ratings
Next Topic: Fiament choke and filter scheme???
Current Time: Wed Nov 04 18:00:37 CST 2026
