Home » Sponsored » Pi Speakers » Where to get JBL 2226 Dustcap Replaced?
Re: Where to get JBL 2226 Dustcap Replaced? [message #97257 is a reply to message #97256] Thu, 07 December 2023 09:08 Go to previous messageGo to previous message
I don't see anything obvious, so I'll bet the problem is underneath a coil. That's the most common problem - they shift during shipping. I allow them to cure for a couple weeks, but I should probably let 'em cure longer.
Lift the middle coil, pulling it free, and see if that doesn't solve the problem. It may have shifted and one of its leads may be touching a PCB trace. If that does it, reattach with silicon adhesive.
If that doesn't do it, send it back to me. I'll fix it and get it back to you while your dust caps are being repaired.
Previous Topic: Insulation Mistake/Question
Next Topic: Definimax 4012HO - End of Life
Current Time: Fri Nov 06 00:15:38 CST 2026
